Need help in Logic gates ckt
mik3
Joined Feb 4, 2008
4,843
First, don't expect from someone to make the whole circuit fir you.
Start with the first term, B'C'D', and make it by using NAND gates. Actually, the first term is a AND gate with NOT gates on its inputs. Make it this with NANDs.
Then make the same with the second term and so on. Finally, OR all the previous circuits together.
Smoor - Oman
Joined Mar 19, 2009
5
Hello... As I said all the Gates should be NAND or NOR gates only!
Thanks for replying, but seiously this is not all my circuit! My desired circuit is to fabricate this combination in CMOS using MicroWind2...
So still I will appreciate it if someone will come up and help me in that...
Thanks
Wendy
Joined Mar 24, 2008
23,812
Try drawing the circuit as a start, then work from there.
You will find we are willing to help, to give hints or to show where you went wrong, but as a rule of thumb no one answers the questions outright, otherwise how will you learn?
Show me a logic schematic, and I'll show you how to start.
vvkannan
Joined Aug 9, 2008
138
Hello Smoor - Oman,
Draw the circuit with noremal gates
Now adding two inverters to AND makes no difference right? .Now replace the AND and first inverter by NAND and represent the second NOT as you have done .
Whenever you encounter an OR gate ,add two inverters at the inputs of OR gate.
Remember one NOT added with OR gives you NAND and replace the another NOT by NAND
example:
say you want to represent x+y by NAND gate
add two inverters in x input and two inverters in y input before it is applied to OR.
Now by our replacement we have x' and y' as inputs for the NAND gate(second NOT added with OR)
so the output is (x' y')' = x'' + y'' = x + y (by demorgan's law) .This is what we wanted
