Need help in circuit
Ravi76450
Joined Aug 16, 2017
The mosfet(irf540) explode during simulation in circuit wizard software.
Please give some suggestions to make it work well and longer life.
Thank you
AlbertHall
Joined Jun 4, 2014
12,625
The only problem I can see with that circuit is if SW1 and SW2 are closed at the same time which would short circuit the 12V supply.
I can't see any risk to the MOSFET as long as the relay coil resistance is sensible - say greater than 1Ω.
bertus
Joined Apr 5, 2008
22,923
The resistor R1 ia way to large.
Now it takes very long to charge the gate capacitor, so it stays a long time in the linear region.
Use a value of 100 - 470 Ohms.
Bertus
AlbertHall
Joined Jun 4, 2014
12,625
Bertus
The time constant is 170uS which isn't huge but I agree the resistor could be a much lower value.
