Hypatia's Protege
- Joined Mar 1, 2015
- 3,228
You didn't solve the problem! You shamelessly cheated! --- So don your dunce cap and wash the chalkboardsSo, what does aptitude mean here after solving this question.
Then again perhaps you were merely checking your solution...?D=speed x time.
S=138.88/10
S=49.99 km/hr
ok, that great interesting.
As long as you solved the problem before looking -- All's cool!no i have not seen just posting that the solving method is different.
Is that good?
That's not a problem it's an identity to wit: 3:2 --- get it? It's a trick question - It's self evident...What about this
Two trains running in opposite directions cross a man standing on the platform in 27 seconds and 17 seconds respectively and they cross each other in 23 seconds. The ratio of their speeds is:
They are testing your alertness -- Notice in the last question they tried to 'trip you up' by 'bringing you to' 13.8889 twice (i.e. 13.8889+125=138.8889 then divided by 10 = 13.8889)how to solve this tricking question.
Rritesh, don't pay too much attention to this...That's not a problem it's an identity to wit: 3:2 --- get it? It's a trick question - It's self evident...
Edited for integer ratio
Stated as a ratio of integers it is exactly 3:2...Rritesh, don't pay too much attention to this...
HP - why not 8:5 instead of 3:2? Isn't it closer to the decimal value?
I apologize that I don't understand what you're asking...Two trains running in opposite directions cross a man standing on the platform in 27 seconds and 17 seconds respectively and they cross each other in 23 seconds. The ratio of their speeds is:
No, i am asking how to solve this?
Well, that would make sense. I'll defer my follow up question until Rritesh discovers the answer.Stated as a ratio of integers it is exactly 3:2...
If you found post #130 confusing - don't worry I just spotted (and fixed) some nasty typosThen how to understand the question situation
Two trains running in opposite directions cross a man standing on the platform in 27 seconds and 17 seconds respectively and they cross each other in 23 seconds. The ratio of their speeds is:I apologize that I don't understand what you're asking...
Hint: You're overthinking it -- just relax and frame the question in your own words -- then it will come to you!Two trains running in opposite directions cross a man standing on the platform in 27 seconds and 17 seconds respectively and they cross each other in 23 seconds. The ratio of their speeds is:
the 27sec is longer train.
& 17 seconds is smaller
both cross in 23sec.
by this hint how to solve further?
there ratio of speed?
