Need help in Aptitude Question
RRITESH KAKKAR
Joined Jun 29, 2010
2,829
ok, there is no distance let it be x.
the speed of both will be different.
time is same.
so. D=s1xt X=s1xt
D=S2xt
S2/S1= ...................................
RRITESH KAKKAR
Joined Jun 29, 2010
2,829
Hint: Ask yourself where train 1 is when the front of train 2 is 'flush' with the observer;)
Two trains running in opposite directions cross a man standing on the platform in 27 seconds and 17 seconds respectively and they cross each other in 23 seconds. The ratio of their speeds is:
ok, the first was still crossing the man 10sec were left on 1st.
RRITESH KAKKAR
Joined Jun 29, 2010
2,829
I's 7:45 AM here and I'd best get my um... beauty rest... My best advice at this point is that you rephrase the problem in your own words -- if all else fails go ahead and solve it via standard algebraic procedure... Talk to you later!:):):)
Best regards
HP
Here is 7:16pm you were talking with me in early morning great .
what is your job.
X-Rays
Doctor?
Actually, I was merely saying that I am essentially a 'layabout' enamored of my hobbies:oops:;) -- FWIW: EHT (also known as 'high voltage') and radiography make for very interesting hobbies! - of course, as with all things useful, they are dangerous in unskilled or careless 'hands'...
So... How's the math problem going?:)
Best regards
HP
PS -- It occurred to me, based upon your earlier post -- That the time-of-day at your location (at the time of this writing) is 12:50 AM? --- Best to get your rest! :):):)
RRITESH KAKKAR
Joined Jun 29, 2010
2,829
I am still on this problem.
RRITESH KAKKAR
Joined Jun 29, 2010
2,829
Two trains of equal length are running on parallel lines in the same direction at 46 km/hr and 36 km/hr. The faster train passes the slower train in 36 seconds. The length of each train is:
The speed in mtr/sec of first is 12.7m/sec, secound is 10m/sec time is 36sec
how to solve forward?
Hint: The difference in the trains' velocities might be regarded as 'rate' in this exercise:)
RRITESH KAKKAR
Joined Jun 29, 2010
2,829
Then how to do this?
Re: The velocity ratio exercise...
Ok... I'll assume you're weary of approaching this from the 'trick question perspective' and wish to solve the exercise in 'standard fashion'?:)
Hint: The conventional (and highly convenient) method of solving problems of this sort is to take a 'simultaneous approach' (CIP - write an equation for each train wherein the respective train's velocity is expressed by a unique variable -- Then solve the equations simultaneously (via addition or substitution)... :)
Hint 2: You're gonna kick yourself -- when you 'spot' the 'trick':D:D:D
Best regards
HP:)
