then how were you earning?
Best regards1 If complex number is written in rectangular form like 32+12i which you can think of like 32+(-144)^.5
What are the angle and magnitude when you think about it as vector?
32+(-144)^.5???1 If complex number is written in rectangular form like 32+12i which you can think of like 32+(-144)^.5
Ya know... If you'd concern yourself with your studies instead of everyone's personal business you be on to your doctoral work by now!then how were you earning?
By working as an IC design engineer.then how were you earning?
32+12i
magnitude = √32²+12²=34.17
angle= tanφ=12/32=0.375
φ=20.55°
integrated circuit or internal combustion engineBy working as an IC design engineer.
Given the nature of this forum, what do you think the most reasonable interpretation is?integrated circuit or internal combustion engine
you must be using waferBy working as an IC design engineer.
Interdimensional Channeler?Given the nature of this forum, what do you think the most reasonable interpretation is?
I can be of more help to you if you tell me where your (mathematical) 'strengths and weakness' lay -- For instance you seem to have trouble formulating equations (as from verbal exercises) as well as with apprehension/manipulation of inequalities -- while, on the other hand, you seem quite proficient at manipulation of 2'nd degree equations and application of vectors...ok let work.
how to solve this?How to add this source?
It's not a yes or no question -- I need to know in what areas of math you require exercise/trainingyes.
Not if you keep asking "How to solve this problem"which will increase my capability and remove lazy
