Need help in Aptitude Question
RRITESH KAKKAR
Joined Jun 29, 2010
2,829
Irrational values cannot be accurately expressed via fractions/expansions so Yes! the correct answer is (√3+1) --- because non-negative values are consistent with 'resistors'
Watch your alerts -- 10 likes coming your way!!!:):):):):)
Hello Hp,
The question was nothing but it has taken my mind, i was thinking we have to do lot of thinking as wb suggestion to make it open an close.
i don't believe i am talking to pilot.
WBahn
Joined Mar 31, 2012
33,315
I like this solution an remember it.
anyway, how i you get 1.5%?
Don't "remember" it, understand the concepts behind it so that you can apply it to problems in general.
The 1.5% comes as follows:
We know that the bounds are 2.67 Ω and 2.75 Ω. So our "best" estimate is the midpoint. You could use either the arithmetic mean (the average) or the geometric mean. The arithmetic mean is
R_{arith} \; = \; \frac{R_{min}+R_{max}}{2} \; = \; 2.708333 \Omega \; = \; 2.71 \Omega
while the geometric mean is
R_{geo} \; = \; \sqrt{R_{min} \cdot R_{max}} \; = \; 2.708012 \Omega \; = \; 2.71 \Omega
As you can see, we have the bounds so tight already that there is no practical difference between the two means.
Now for the tolerance we just take the difference between one of the bounds and our best estimate and divide by that best estimate.
\frac{\Delta R}{R} \; = \; \frac{2.71 \Omega \; - \; 2.67 \Omega}{2.71 \Omega} \; = \; 1.599 %
If you don't do any rounding you get 1.538%.[/tex]
WBahn
Joined Mar 31, 2012
33,315
(1 Ω)(Req) = (Req)(1 Ω) + (Req)^2 - (2 Ω)(1 Ω) - (2 Ω)(Req)
(Req)(1 Ω) + (Req)^2 - (2 Ω²) - (2 Ω)(Req) - (1 Ω)(Req) = 0
(Req)^2 + (Req)(1 Ω) - (2 Ω)(Req) - (1 Ω)(Req) - (2 Ω²) = 0
(Req)^2 + (Req)[1 Ω - 2 Ω - 1 Ω] - (2 Ω²) = 0
(Req)^2 - (2 Ω)(Req) - (2 Ω²) = 0
Why are you Ω² the unit?
Think of area. If you have a rectangle that is 5 m on one side and 10 m on the other, the area is 50 square meters, or 50 m².
Mathematically it is all consistent because you are multiplying
A = (5 m)·(10 m) = 5·10·m·m = 50 m²
RRITESH KAKKAR
Joined Jun 29, 2010
2,829
from where we got this term?
i have studied arithmetic mean (the average) or the geometric mean but in real i on't get it.
from where you study so deep?
WBahn
Joined Mar 31, 2012
33,315
but Ω² does not make sense
Remember that this is an intermediate, mathematical expression. Intermediate terms seldom have any direct physical meaning.
But let's look at how the units work out
a = 1
b = -2 Ω
c = -2 Ω²
R_{eq} \; = \; \frac{-b \; \pm \; \sqrt{b^2 \; - \; 4ac} }{2}
R_{eq} \; = \; \frac{- \( -2 \Omega \) \; \pm \; \sqrt{ \( -2 \Omega \) ^2 \; - \; 4\(1\)\(-2 \Omega ^2\)} }{2}
R_{eq} \; = \; \frac{2 \Omega \; \pm \; \sqrt{ 4 \Omega^2 \; + \; 8 \Omega ^2} }{2}
R_{eq} \; = \; \frac{2 \Omega \; \pm \; 2 \Omega \sqrt{ 1 \; + \; 2} }{2}
R_{eq} \; = \; \( 1 \; \pm \; \sqrt{3} \) \Omega
You treat units just like any other factor.
