Need help in Aptitude Question
Aleph(0)
Joined Mar 14, 2015
597
HP at rate you're going you'll be showing him the jacobian by next week!;) I say rigor is good but can be too much of good thing when it scares student away:rolleyes:! I know you will say it worked for me but don't forget I'm not normal:eek:! :D!
I think you'll never let me hear the end of that:rolleyes: -- Seriously, do you really begrudge that past 'rigor' in light of it's instrumentality to you present 'fortunes' -- Think about it???:cool:
--Emphasis added --
No fear of that!:D
All the best
HP:)
I'm only sticking around to see how long this ridiculous thread gets before it dies. My guess: 500 posts, MINIMUM.
Sadly, there would seem to be something to what you say:rolleyes: Seems my 'pupil' is 'playing hooky':mad: -- and after all my efforts on his behalf! - Whatta world!:(o_O
@RRITESH KAKKAR
My offer yet stands -- 10 'like points' should you choose to solve the exercise presented by post #359:)
I should think academic achievement would be its own reward - still... whatever works...:rolleyes::)
Best regards
HP (The Ever Optimistic);):D
Ha Ha Ha Ha!!!! ROTFLMAO!!!
You've stated before that you are not, and have never been, a teacher. Now you have provided clear proof of that assertion! :D:D:D:D
Touché:) -- As per my user name I am an inveterate student --- Also as per my username I have the utmost respect for bona fide instructors!!!:):):)
Sincerely
HP:)
RRITESH KAKKAR
Joined Jun 29, 2010
2,829
---Edit @ 18:47 (UTC - 6:00) 10 Dec 2015 --- All typos 'eradicated'!:):):)---
As I understand post #357 you want a more 'interesting' exercise? -- Inasmuch you did well yesterday - I offer this fun exercise:) -- As incentive I will grant you 10 "likes" if you solve it!:):):)
What is the resistance apparent 'across' Nodes P and Q for the network pictured below?
Note: Please do not resort to analysis!
-- Perhaps counterintuitively, this exercise is readily solved via purely algebraic techniques! I promise!!!:):):)
Hint 1: Note that the resistance of the semi-infinite 'section' is not altered via removal of preceding 'stages'...
Hint 2: Hint #1 is very important! -- Please consider it!:cool::cool::cool:
Hint 3: This is actually a very simple problem! -- Don't be distracted by 'infinity'...:)
You probably already know this -- however for completeness sake
Resistors in series: Reffective = The sum of resistances (i.e. Reffective = R1+R2+R3...)
Resistors in parallel Reffective = The reciprocal of the sum of the reciprocals of the resistances (i.e. Reffective = (1/R1+1/R2+1/R3...)^-1
Again, do not use analysis (i.e. Calculus, etc)!!! -- Doing so will disqualify your answer!
OBTW Don't bother searching the web for the 'answer' - most sites offer incorrect solutions!:p:D
Yesterday, i was at home.
as R is 1 ohm.
so, P & Q as you said Hint 1: Note that the resistance of the semi-infinite 'section' is not altered via removal of preceding 'stages'
it should 3 ohm
1+1+1=3
WBahn
Joined Mar 31, 2012
33,244
as R is 1 ohm.
it should 3 ohm
1+1+1=3
Let's ask if that answer makes sense.
If we remove all except the first three resistors, then the total resistance would be 3 Ω. But, in order for the solution to be 3 Ω when all of the resistors are in place, that means that adding back in all of those resistors, which are in parallel with the middle resistor of the three, has absolutely no effect on the resistance. Does that make sense? In fact, if the total resistance is 3 Ω, that means that the resistance of the section we removed was 3 Ω, which means that when we put it back in place we now have a total resistance of 1 Ω + (1 Ω || 3 Ω) + 1 Ω, which would be what?
