Need help identifying one component in the attached screenshot
aviralp
Joined Feb 17, 2024
What are the triangle indents on the wires connected to pins 1 and 4, also what the slider connected to first triangle indent means?
35,245
What you see is the circuit symbol for a TRS jack.
TRS = Tip, Ring, Sleeve
These are the electrical contacts to the plug that is inserted into the jack.
The triangle is NC (normally closed) switch contact. When the plug is inserted into the jack, the switch opens.
dl324
Joined Mar 30, 2015
18,479
Welcome to AAC!
They're contacts on the connector.
The "up arrow" on the top connection isn't a slider. It represents a normally closed connection that opens when something is plugged into the connector.
