NEED HELP-Hitachi VHS camera not recording
WaddleDee72
Joined Jul 4, 2017
Hi everyone,
I would really appreciate your help on this issue. I have an old Hitachi VHS camera from the 1980s, and when I turn it on, the viewfinder works perfectly, but pressing the record button does nothing. It used to work; the camera used to make noise when I turned it on, presumably pulling out the tape from the VHS, but now it doesn't anymore. Playback also doesn't work. If anyone has any ideas on what might be the problem, that would be greatly appreciated!
Dodgydave
Joined Jun 22, 2012
11,395
Vhs system used a light bulb/led in the centre of the cassette holder, and light sensors at each end of the tape tray, if this is not working the video assumes there is no tape inserted., failing that you will need a service manual.
wayneh
Joined Sep 9, 2010
18,120
You might want to consider what it’s worth if you succeed. My guess would be next to zero. Could be wrong, but worth a look?
