Ah I see, I forgot there are still diodes in a SMPS to convert main AC to high voltage DC. Thanks DickCappels.It is neither common mode nor differential mode noise by itself. It is RF getting to the diodes on the input of your power supply which then modulate the RF. These are the diodes in the switching power supply that convert the incoming mains voltage to DC, prior to switching.
You should gain some insight from the article at the URL below.
http://home.computer.net/~pritch/shortwav.htm
PS:
I did tried a few different SMPS, from cheap to decent one. They all have hum. Maybe I should try one from Apple, I was told they are well engineered. (If I can get an Apple phone/laptop charger)
