Need Help: Generating –12 V from a 12.6 V Li-Ion Battery
DJ_AA
Joined Aug 6, 2021
502
Hi all,
I have 12.6 V supplied to my circuit by a Li-Ion battery. I also need to generate a negative 12 V. Could someone please advise how this can be achieved?
dl324
Joined Mar 30, 2015
18,513
You need an inverting switching regulator:
The voltage is set by the ratio of R1 and R2, so it should work with a 12.6V input.
DJ_AA
Joined Aug 6, 2021
502
What is the max current output? Is it possible to do it with out a dcdc I need it create short pulse of 1s for a solenoid
35,291
If you have an extra 12 V battery, just reverse the connections to the battery, i.e. positive terminal goes to GND.
35,291
Does reversing the current through a solenoid makes the solenoid eject?
I don’t think so unless the bar is a magnet.
