NEED HELP FOR SCHEMATICS
dl324
Joined Mar 30, 2015
18,490
Welcome to AAC!
can someone help me make a schematic diagram with these sensors, temperature, pH level, and turbidity. I am using arduino uno and the app is protecus.
Make your best guess at a placement that will minimize wire crossings, bends, and jogs. Then start connecting things. If you find that your initial placement isn't good enough, move things around.
What you'll end up with will be more like a wiring diagram, not what most would consider a schematic.
You really don't need to use all caps in your title (or username). That's sometimes interpreted as yelling.
28,488
In order to get any engineering help such as the interconnections required you will need to provide information about the devices you want connected, and what you want too achieve. And if you only provide links for that standard consulting rates would apply. I finally found the post that has not been locked, is why my response is so delayed.
And if this really is schoolwork and not a project of some sort, what sort of class is it for?
And the reason nobody has jumped in to help is because there is no useable information about the project in your post.
I have designed many testing machines in my career and so I am aware of just what is needed, and what is missing.
BobTPH
Joined Jun 5, 2013
11,665
It is unclear to me whether you are asking how to draw the connections, which you know, or what the connections ought to be, because you don’t know.
