Need help for lead acid battery charger
MikeML
5,444
The Circuits Today description of the LM317 circuit is horribly mixed up.
That circuit has been around for years, and they just reprinted it with a wrong description and lack of attribution.
That circuit has a major design flaw. Think about what happens if the input supply voltage drops below the battery voltage plus the drop-out voltage of the LM317!
The battery discharges backwards through the voltage divider resistors... Very poor design...
Here is a better circuit.
embpic
Joined May 29, 2013
189
yes sir but after limiting current by changing 0.51 ohm resistor to 2 ohm then this will limit the current.
and how could we limit the current at supply.By introducing resistor???
wayneh
Joined Sep 9, 2010
18,184
I do not understand your last question. Limiting the current to the load serves to limit the current drawn at the supply.
The LM317 should be protected by a reverse biased diode from output to input. This will save it if/when the supply is removed while the battery (or output capacitor) is still connected. Applying power to the output without an input can damage the LM317.
