Need help finding the value of this resistor
eDigitCom
Joined Apr 27, 2021
29
1R3W would suggest that it's resistance is 1 ohm with a power dissipation rating of 3 watts. I agree with Yaakov. Measure it's resistance. The colour coding of the resistor looks like black, black, black, silver , black. This does not make sense so it i possible that the colours have changed if the resistor was running hot. (But if it was removed from the board in your photograph that does not look like it has been effected by heat from the resistor.)
Les.
yes was removed
BobaMosfet
Joined Jul 1, 2009
2,211
1R3W could also mean 1.3W.... albeit an odd way to do it. Can anybody tell what the color bands actually are, and what direction to read them in? One way sorta makes sense, the other doesn't....? Is that light-colored band white or silver?
I can understand the TP's confusion.
000 x 0.01 .... I'm leaning towards this being a *really low* value resistor, like 0.01 at 1% tolerance, and it's a 3W resistor....?
eDigitCom
Joined Apr 27, 2021
29
The image was taking under a microscope. The best you get the condition of it does not look good I think it is white
eDigitCom
Joined Apr 27, 2021
29
the meter reading is 4.4 ohms
Deleted member 115935
Joined Dec 31, 1969
I measured in Diode mode
Diode mode, is unless its a real expensive meter, based on a standard silicon diode /gate drop, so the schotkey will be forward biased by most meters.
So one way you will get a drop, the other it will be open circuit, just as you have.
Ya’akov
Joined Jan 27, 2019
10,258
It's a 5 band resistor so if the colors were once brown-black-black-silver-gold it would be a 1Ω 5% resistor.
LesJones
Joined Jan 8, 2017
4,509
What is the device that the resistor was removed from and what were the fault symptoms that made you suspect the resistor ?
It would help if you can post a schematic of the area around the resistor.
Les.
eDigitCom
Joined Apr 27, 2021
29
Les.
AKAI speaker logic power Fault: No power I have no schematics for it I show an image of the resistor removed and from it you can see the text 1R3W on the board
