Need help finding replacement potentiometers
Citroenbob53
Joined Sep 11, 2017
Hi all
I have a Mig welder which has a pulse and stitch facility, unfortunately the switched potentiometers are both broken.
The pots are marked either PITER 4701316 or PITER 470316 very difficult to read.
Could someone help with recommending replacements
Cheers in advance
Rob
MaxHeadRoom
Joined Jul 18, 2013
30,858
Most likely Piher product, they make a range of pots, can you measure the resistance on the outer ends still?
If you can get the value they are easily available make sure you get linear versions.
Max.
