Need help detecting AC input with microcontroller
AverageMoss
Joined Apr 24, 2021
34
Hello, I'm working on a project where I need a microcontroller to detect a couple of 24 VRMS AC inputs from a thermostat. The inputs only need to be read as high or low. It also needs to be physically as small as possible as the circuit board has to fit in a small space.
I've come up with a design but I'm not sure if it would work. It uses a feature of the microcontroller called Analog-to-Digital Converter (ADC) and 113k ohm resisters between the input source and microcontroller pins.
I'm a little new to this stuff so any feedback is greatly appreciated. Here is the schematic:
djsfantasi
Joined Apr 11, 2010
9,237
You may only need one diode to as a half-wave rectifier on the AC input. The voltage would be smaller than with a full-wave rectifier. The input voltage would be smaller (by 1/2) but could still be detected. One diode would be smaller than a bridge rectifier.
AverageMoss
Joined Apr 24, 2021
34
what do you need to do ? to detect a couple of 24 VRMS AC what does detect mean ?
I just need to read the 24 VRMS inputs as high or low (on/off). For example, if the "G" input (pin 5 on the microcontroller) was high then that tells the microcontroller that the "fan-only mode" is selected.
38,712
Since the AC from the thermostat is isolated by its transformer, an opto coupler is not needed (at least for safety considerations).
Jerry-Hat-Trick
Joined Aug 31, 2022
840
The peak to peak voltage of 24VAC will be around 34V positive to 34V negative. Even with 113K resistors I expect you will destroy the processor A/D lines. At the very least you would need a potential divider - maybe a diode in series with a 100K reisistor in series with a 10K resistor to ground and sniff the voltage between the two resistors which will be a maximum of around 3V. The diode protects the processor from the negative voltage by appearng like a high resitance value.
Personally, wherever AC is about, I prefer to use an opto coupler to isolate ffrom the comtroller circuit. A similar potential divider (with order of magnitude lower values) will send current through the opto diode whilst protecting that diode from reverse voltage
AverageMoss
Joined Apr 24, 2021
34
@djsfantasi @Jerry-Hat-Trick
After reading all of the replies I came up with a new temporary proof of concept design.
This is new territory for me so I don't know if something like this would work. I would appreciate it if anyone can point out everything wrong with the design. I only have the G input wired for now on purpose.
djsfantasi
Joined Apr 11, 2010
9,237
I still think you need a pull-down resistor joined to the connection between the optoisolator and the GPIO pin. Forgive the crude drawing; I hope you understand it. Use a 10kΩ resistor on each pin.
AverageMoss
Joined Apr 24, 2021
34
Updated the design. I added the 10k ohm resistor as well as a 100k ohm resistor to current limit the AC input to the optocoupler. Something like this for each input (G, Y1, W1, W2, *).
AverageMoss
Joined Apr 24, 2021
34
Does that work?
100K seems high, that's only .24ma to activate the opto. I would design for 10ma using a 2400 ohm series resistor.
You're absolutely right. Thank you for that!
Correct me if I'm wrong, but I think I'm at the point where I can purchase components and test them to see how this works:
