Need help converting this relay latch to solid state.
Vakito227
Joined Sep 8, 2018
5
Hi all, I'm thinking of adding an extra security feature to my 80's Volvo to prevent thieves from starting and stealing it. Basically I'm wanting to add a secret button you have to press once you turn the key to provide power to the ignition system, like a basic immobiliser. If you don't press the button first, the engine will just crank and not fire.
The easy thing to do would be to just have a physically latching button but after a while I'd just become lazy and leave it latched down defeating the purpose of it.
I've drawn up a plan for the circuit using relays but relays can be bulky, expensive and are prone to shock and vibration in a moving car. Can anybody adapt my plans into a solid state circuit?
I believe the ignition system is a few amps but I'd like it to handle 10A just to be safe.
Peter
38,830
Here's the LTspice simulation of a solid-state latch circuit using a BJT and a P-MOSFET that should do what you want.
The P-MOSFET can be just about any with a ≥20V voltage rating and a ≤10mΩ on-resistance (to avoid needing a heatsink for the MOSFET @ 10A).
The ignition switch in series with the 12V that applies power to the circuit is not shown.
(V2 is just for simulation of the push-button).
P.S. Is it rude to ask why you think anyone would want to steal an 80's Volvo? :D
Vakito227
Joined Sep 8, 2018
5
Hi there thanks for the design, I've drawn it up myself hopefully there's no errors!
Well, I suppose it's not the most desirable car to thieves but you'd be a fool to underestimate the yobs around my area! Currently the only security feature on the car is the key!
Cheers
