Need help capacitor discharge question
wertyu
Joined Jul 13, 2020
10
I got it wrong twice and i made a silly error now im on last chance to pass .
can someone check my answer and given advice for me , it would help a lot .
thanks
capacitor discharge
10v supply - total resistance in circuit 10.3 Kohms - 100microfarad capacitor .
need to find Volt and Current at 1 sec and 2 secs .
below is my work
Voltage = 10 x ( e -t/tc)
1 sec = 10 x 0.379 = 3.79v
2 sec = 10 x 0.14 = 1.4v
Current Io x (e-t/tc)
1 sec 0.00097 x 0.379 = 0.000367a
2 sec 0.00097 x 0.1437 = 0.000143a
Alec_t
Joined Sep 17, 2013
15,152
Welcome to AAC!
Re-check your equations for voltage and current. They are incorrect.
Show each stage of your working.
wertyu
Joined Jul 13, 2020
10
ok
time constant = 10300 ohms x 0.0001 microfarad = 1.03 secs
Voltage
1 sec 10V x e to the power of minus (1 / 1.03 ) 0.97 = 0.379 10 x 0.379 = 3.79V
2 sec 10V x e to the power of minus ( 2 / 1.03 ) 1.94 - = 0.14 10 x 0.14 = 1.4 V
Current
10 / 10300 = 0.00097 amp
0.00097 x e to the power of minus 1 / 1.03 0.97 = 0.379 = 0.00097 x 0.379 = 0.000367a 0.367ma
0.00097 x e to the power of minus 2 / 1.03 1.94 = 0.14 = 0.00097 x 0.14 = 0.00013 0.1ma
Alec_t
Joined Sep 17, 2013
15,152
0.0001 microfarad
No. Carelessness with units will lose you marks.
You are still not showing all your working, which can lead to confusion. This line, for example:
"1 sec 10V x e to the power of minus (1 / 1.03 ) 0.97 = 0.379 10 x 0.379 = 3.79V"
would read more clearly as:
"At 1 sec, capacitor voltage = 10 x (e^-1/RC) = 10 x (e^-1/1.03) = 10 x e^-0.97 = 10 x 0.379 = 3.79V"
As the voltage at 1 sec is expressed to two decimal places your tutor may expect the voltage at 2 sec to be expressed likewise, i.e. as 1.44V.
