need help building a 48v charger
ElectricTicTac
Joined Feb 9, 2017
10
Hey Guys,
I'm on a journey to build a "dirt cheap EV" to prove to people that 1) you don't need to spend gazillions to own an EV commuter and 2) any dum dum, namingly me can build one.
so Ive acquired 48 (VRLA, 12v, 33ampere) batteries from the scrap metal yard and I need to find a way to charge 40 of them as a 48v pack, Ive created 4 series strings of 10 and made the whole pack parallel with soft copper pipe hammered flat bus bars. (I have a 48v AC 3-Phase induction motor and 48v 500a controller from a forklift)
Ive also acquired 4 x DPS1200FB A Power supplies: input 200v-240v ~/7.8A, output 1200 MAX, +12V / 100A MAX. I've successfully modified one of them to output 13.5v. the float range for the cells are 2.23-2.27 (13.36-13.62) so its good enough for a float voltage but I really need a boost charge as well, not sure what a boost charge would be but I'm guessing 15v
So I need a charger that can ideally adjust voltage from 48-60v and the Current as well, I'm guessing 1-?10? Amps or however many Amps required to charge 1320Amperes of battery pack, not that they will have 1320amperes as I retrieved them from the scrap yard.
and to conclude I'm a total electronic muggle... I need to find a cheap solution but I don't mind paying a few dollars for a pre configured circuit board/ components, just not $2000 dollars NZD!. I had a look on ti.com at DC/DC step-down regulators/buck controllers but the battery management components either weren't in the right voltage range or the current was too low..
48v chargers are rare and super expensive here in New Zealand same goes for technical support..
hope you can help
thanks in advance
Stephen
ElectricTicTac
Joined Feb 9, 2017
10
Hi, thanks so much, that was a good recap also learnt new things. the batteries might be knackered but I swapped all the old batteries I had and paid a little extra in cash, even if they only get me up and down the road it'll be a good learning curve and I can return them and get half my cash back, it would've only cost $200.
so, i really want to get these batteries charging, are there any off the shelf semiconductors and schematics, i dont necessarily need to build something up, even if i pay a little extra for an all in one voltage regulator current regulator that I can connect to my Power supplies in series 48-60v. although ideally i would like an automated system. just seems the prices of 48v battery chargers are exorbitant...
cheers :)
ossix
Joined Feb 12, 2017
2
Have you checked the junk yard for old man/aerial lifts? The battery operated models usually use 8x6v batteries and would have all the components necessary to build the charger you need. It would likely be a trickle charger (most seem to be rated for less than 5A.
ElectricTicTac
Joined Feb 9, 2017
10
thanks Mate, good idea but I think the chances would be pretty low of finding an aerial lift in the junk yard here in NZ unfortunately. most scrap metal yards don't even allow someone off the street access.
Kermit2
Joined Feb 5, 2010
4,159
Look into solar charge controllers.
You just have to feed them DC, not necessarily from a solar panel either. Nudge nudge, wink wink.
One that will take up to 150 to 200 VDC as input would be perfect, but the affordable ones seem to be limited to about 70 volts input max.
Solar companies should be able to price you out a unit that would accept the input levels you need and would come ready to charge the batteries without internal modification.
ElectricTicTac
Joined Feb 9, 2017
10
that's a great idea, would kill 2 birds with one stone but I heard that solar charge controllers don't like a DC source other than from PV's? or is that sales talk? I don't know why, don't understand. would hate to destroy it, but if there's no issue with feeding a power supply DC source into a solar charger then I'm keen!
Kermit2
Joined Feb 5, 2010
4,159
Cheapese manufacturers probably make units that won't operate well with a little hum in the input, but any major manufacturer will have designed a circuit with plenty of tolerance for such a minor annoyance.
If you have a steady source of DC above 60 volts and with more wattage available than your charger can deliver then the presence of a little AC hum will make little difference.
Be sure the power supply has a large overhead of available power.
Rectified AC supplies have horrible output waveforms when pushed to the rated limit of power output.
Don't use a 1000 W dc supply to power a 900 W battery charger that needs clean DC voltage.
Use a 1500 to 2000W supply instead. The DC will have much less AC noise this way. This will prevent any problems if you go with a solar charge controller. Remember they deal with voltage that changes, just much more slowly than 60Hz, so they can operate with changing voltage levels, but best to keep it small changes. Not approaching the upper power limit of your supply will prevent large AC variations from appearing in the output.
ElectricTicTac
Joined Feb 9, 2017
10
Thanks for the lead Kermit! using a solar charge module what I originally wanted to do, its multipurpose and future proofed (to a degree) one day I can buy some PV's :) and power the house :)
ronv
Joined Nov 12, 2008
3,770
Something you might find cheap is a golf cart charger. It might be a little slow (15 amps I think) but you might get one cheap.
tcmtech
Joined Nov 4, 2013
2,867
If you modified them to get 13.5 volts just take them the extra ~1 volt more to get into the proper ~14.5 volt range you need and skip the extra work and cost of adding more power supplies.
ElectricTicTac
Joined Feb 9, 2017
10
Is it technically possible to connect 6 12v PSU's in series and then use a Current and voltage regulator? My VRLA batteries need 14.4v for a bulk charge.
Modifying PSU's seems to be the absolute cheapest way to charge batteries? If it was possible.. theres a few good instructsbles for turning PSU into lab supplies and even connecting in series but I can't find much on charging a 48v pack.
No luck with second hand or cheap golf cart chargers or Solar Charge Controllers as yet..
Thanks for your patience.. :)
