AlbertHall
- Joined Jun 4, 2014
- 12,640
When 110V input power is applied the relay should operate to switch to 110V.Albert hall, what were you thinking?? I am not really following you. I agree with 220 connected to the NC position, if I am running both 110/240 thru one cord, the coil would be energized if I applied 110v to energize the coil to trip the NO circuit, but when the 240v hits the coil if it is a 110v coil it will burn out would it not?
When 240V input power is applied the relay should NOT operate to leave set to 240V input so 240V would NOT be applied to the coil and so a 110V relay coil will never have 240V applied to it.
Therefore you need a circuit to only energise the relay coil when 110V is applied but not when 240V is applied.
