MP9486 Buck Converter for 72Vin to 16Vout at 1A Iout. Need Help with Building Power Stage.
atalla cooper
Joined Jan 3, 2022
Buck Converter for Automotive System using MPS's MP9486 IC, It has Hysteretic Voltage Control Mode which. This was a task from an EV startup. I looked into the datasheets, and also some videos. There isn't much Reference for this IC, And I really want to know how to proceed with this. I am a fresher to Power Electronics from Electronics and Communication Engineering, I'm getting stuck at selecting the capacitor values and Setting the Frequency. I have attached the Documents that I have as reference.
LowQCab
Joined Nov 6, 2012
5,101
Lets start from the beginning ..........
1) Describe your Power-Source.
2) Describe your Load.
3) Describe the desired end-result under all possible circumstances / conditions.
4) Why did You choose this Chip ?
5) Why did You choose a Surface-Mount-Package ?
6) Will this device represent a continuous Load on the Batteries ?, and does it matter ?
7) Will this device be used in an Electric-Vehicle ?, or some type of hand-held device ?
8) Do You intend to use the "Demo-Board" ?
9) Do You have experience in working with Surface-Mount-Devices ?
