I have swapped 1zzfe engine in my Carina e 98, car has ABS sensors but the engine doesnot have a VSS sensor (3pin) its ecu can only read square wave signals ( 4 pulses/ rev of wheel) while ABS sensor is of reluctance type, i need help related to
1.. Make a converter circuit that can convert sine wave to square wave
2.. Then convert its high frequency to low frequency, i.e. ABS reads 48 pulses per revolution of wheel.
Please help me, i did all the engine swap and wiring myself and wanto design this circuit too.
The ecu shows only VSS code 500 error, and car does not engage 4th gear in ECT auto transmission ( the one with +/- and S)
Help please
Help please
