Many thank for your replay,The circuit is a Sallen-Key second order lowpass filter.
Many thanks for you.Since I am not a teacher then you should look it up in Google.
A good second-order filter has a Butterworth response which is flat in the passband then a sharp cutoff. A Bessel response has a droopy and slow cutoff but has less phase shift than a Butterworth.
Usually a Butterworth filter with a gain of 1 like the circuit you showed has equal values for the resistors and the first capacitor value is double the second capacitor value.
Thank you
Thanks for that hintThe input to R1 is normally an AC signal, not DC as shown.
