I am using NE555 timer..and relay used is 12v relayIt depends on which model of 555 chip and how much current the relay needs.
You did not tell either of these.
version of 555 means?You might want to add the diode to prevent the flyback current in the relay from flowing backwards through the '555 output. Some versions of the '555 might be damaged without it.
Source of above: http://www.electroschematics.com/7103/555-tlc555-relay-driver-circuit/
The NE555 can supply 200 ma but you did not tell the current your relay uses. You told the voltage.relay used is 12v relay
Not all '555's are of the same design. Some might be more sensitive to this reverse current flow than others. As I recall, the original intersil application booklet indicated that this diode is a good idea for their (original) version of the NE555.version of 555 means?
RelayThe NE555 can supply 200 ma but you did not tell the current your relay uses. You told the voltage.
Can you please tell me how to know the current required by the relay...It is not present in the datasheet evenLm555, TLC555, SE555, ICM7555, and a few others.
Try Google 12V 0.36W 30maCan you please tell me how to know the current required by the relay...It is not present in the datasheet even
