Need Formula Concerning RC Timing
Mathew Lewis McGill
Joined Nov 5, 2015
4
I have a circuit that generates a pulse width. What I need is a formula to determine the time it will take for the output to switch given a voltage at the noninverting input to the comparator.
22,084
Let's see a +5V source
R=1.62 MΩ
C=10nF
The response of an RC circuit is
\(v=5(1-e^{\frac{-t}{RC}})
You should be able to answer your own question with a bit of algebra
Mathew Lewis McGill
Joined Nov 5, 2015
4
Yippy, a quiz.
OK, was you hoping that I'd show you? Cause I found that equation; It's all over the place.
I was kind'a hoping to get an equation to solve "t"
22,084
R=1.62 MΩ
C=10nF
\(\frac{v}{5} = 1-e^{\frac{-t}{RC}}
\frac{v}{5}-1=-e^{\frac{-t}{RC}}
1-\frac{v}{5}=e^{\frac{-t}{RC}}
Take the natural logarithm of both sides
\(ln(1-\frac{v}{5})=ln(e^{\frac{-t}{RC}})
Can you take it from there?
Mathew Lewis McGill
Joined Nov 5, 2015
4
for a voltage of 125mv, the delay is 410.2ms
You're good with algebra, but seriously struggle with providing a simple straight answer.
By the way, I plugged the original equation in Excel and massaged the numbers.
If it's not too painful, I'd appreciate that equation now.
Thanks
22,084
Guess not.
\(ln(1-\frac{v}{5})=\frac{-t}{RC}
-RCln(1-\frac{v}{5})=t
Are you really sure you could not have done that?
Remember ln is the natural logarithm, or log to the base e (≈2.718281828...), and log is logarithm to the base 10. Seriously struggle with providing a straight answer? If I show you, but you don't understand how it is done, you'll just keep having to ask other people to solve your problems for you. Struggle a bit on you own and you'll remember how to do it next time it comes up. We're here to help not spoon feed answers to you.
Also -- try not to bite the hand that feeds you next time. Petulance is unbecoming.
32,958
Congratulations on tricking someone into doing your homework for you. Doesn't happen too often around here, but it does happen from time to time.
