hello everyone!!! I need TGD4000 oscillator datasheet but
there is nothing on the web. can someone help me?
What other info do you have? manufacturer, physical format, frequency, output voltage, etc, etc.?TGD4000
It is, the 4000 refers to the frequency. TGD possibly refers to the company Shenzhen Tgd Crystal Electronics Co., Ltd but I can't find them online, the website www.sztgd.com is offline.The photo is poor but that looks like a crystal, not an oscillator.
No you don't - as I suggested above - build it on a breadboard as shown. Check frequency. If its 4MHz then you have a working solution. If its off frequency then you have a parallel crystal which needs a different oscillator circuit. You can't tell which type you have from the part # marked on the crystal, so the datasheet is of no use to you. You can only tell by trying out. If its a parallel type come back and I'll advise what to do next...i need 1Mhz frequency so i will use 2 Flip Flop D to divede by 4 frequency...but i need datasheet to see which cap i must use
