Need advice on Projector Disassembling
Stat7
Joined Jul 19, 2013
1
I have disassemebled a Pico Projector and I want to keep the projection module separate from processor board which are connected by three ICs. Basically something like a ribbon cable 1 feet long which allows me to connect the module and the board in an extended fashion would be perfect. I have added an image (the three open ends go into the ICs below - this is connection I want to extend). Is this possible? How can I do this?
18,140
Somewhere between really hard and impossible. You'd need a male-female extension ribbon with the particular footprint or whatever it's called. Not likely, IMHO.
Kermit2
Joined Feb 5, 2010
4,159
You can map out the connections and replace them individually one by one with wire of the length you require.
Brand new issues with radiated freq's and impedance delays are sure to follow.
I'd love to see that hack if you attempt it though :)
