Need advice on Op Amp or Switching Regulator 20V -> 5V
eduncan911
Joined Nov 14, 2011
29
What Switching Regulators and/or Op Amps do you recommend to take a 19.5V & 4.5 Amp / 90 Watt input and regulate it down to variable 5V @ 7A (variable)?
I only first heard of an "Op Amp" today, so this is a new concept to me.
I am building a project that have 5 variable loads.
So that's around 7 Amps @ 5V max draw. I do have a 6A @ 5V power supply; but, it's just under the required max draw.
The single power supply I wish to use is an old Dell power supply to keep the project nice and clean. I have several rated at 19.5V and ranging from 90W to 140W (4.5A @ 19.5V and 7A @ 19.5V respectfully).
I can solder and can make up the connections.
I've never used an Op Amp nor a switching regulator and have no idea where to start. I was reading online that resistors are not ideal for this kind of variable load and amount of amps.
Thanks in advance!
BobTPH
Joined Jun 5, 2013
11,678
An opamp is cannot do that (though it could be part of a circuit that does that).
To go from 19.5V 4.5A to 5V 7A, only a switch mode DC to DC converter will work. A linear regulator (which is what I think you really meant by opamp) cannot increase the current, while a switch mode buck converter can.
Bob
AnalogKid
Joined Aug 1, 2013
12,302
Because the output current is greater than the input current, you will need some form of a switching (not linear) regulator. A simple buck regulator from ebay will give you a single output capable of up to 7 A output current. If you want more isolation among your loads, you can use a group of smaller buck regulators, with maybe only 1 or 2 A output current capability. That will cost a bit more, but a single failure either in the regulators or in your load systems will not take down everything.
ak
Dodgydave
Joined Jun 22, 2012
11,395
Thanks in advance!
Some laptop psus can be modified to make a lower output voltage, by altering the resistors on the Tl431 zener regulator,.
Failing that add a Lm2596 ready-made buck regulator on the output.
