Need advice for a circuit to turn off a small transmitter when dark
jonnyvee
Joined Mar 6, 2021
5
I'm trying to find a circuit or Photocell that will run on 4-5 volts and turn off a small transmitter at night, I have a 6 volt solar cell with voltage dropped to 5 volts going into a charge controller that is powering a transmitter and charging a 3.7 volt battery for backup, I would like it to turn off the battery when the sun goes down as it doesn't need to work at night but can't find a photocell or similar device that does that, also need it to be small, anyone have a idea or where that could be found?
Bernard
Joined Aug 7, 2008
5,784
A diode could be connected between solar cell & battery, cathode to battery.
What needs to be disconnected, SP from battery, battery from Tx, , SP from Tx ?
jonnyvee
Joined Mar 6, 2021
5
The battery kicks in when the solar cell has no light, need the battery to go off when dark so like a off at dusk photocell
Ya’akov
Joined Jan 27, 2019
10,346
Does it need to operate on cloudy days when the light is poor?
