Need a help in using ht12e
Layan_AK
Joined Mar 28, 2017
79
Hi All,
I'm trying to build a wireless remote control using rf transmitter and ht12e.
I used the following circuit ..
The circuit worked correctly after several times of pressing the button ..
but when i connect the TE pin to ground directly the circuit worked correctly all the time :(
regards :)
Dodgydave
Joined Jun 22, 2012
11,395
So just press the te button when you want to transmit the data to the receiver.... what's the problem then?
thank u for ur reply :)
OK :)
But I don't need to enable the transmitting all the time ,i need to enable it only when i press the button.
Regards :)
Layan_AK
Joined Mar 28, 2017
79
i need to enable the transmitting only when i press the button not all the time to save power.
it needs 10-14mA when i enable the transmitting all the time :(
