Need a circuit for interfacing latching relay to micro controller
Mayuri1234
Joined Apr 7, 2014
7
I am using pic16f1787 as my main controller. I want to use a latching relay to interface with the controller. Attached is the datasheet for the relay.
I am aware that there are two types of latching relay-single coil relay and dual coil relay.
I need a circuit for both relays so that I can choose the one with less hardware and implement the design.
Please help.
Regards,
Mayuri
38,770
The dual coil relay will require two transistors (either two MOSFETs, or two BJTs with two resistors) and two diodes.
The single coil design will require 4 MOSFETs connected as a bridge and no resistors and diodes, or 4 BJTs connected as a bridge with 4 diodes and 4 resistors.
Either configuration will require two outputs from the micro, one for set and one for reset of the relay.
If you tell me which configuration you prefer, I can post a conceptual circuit.
Sensacell
Joined Jun 19, 2012
3,787
Are you sure the single-coil unit requires a polarity reversal to unlatch?
I think it's just bi-stable- latch-on, latch-off every other pulse?
This configuration would be easy to manage if you could monitor one set of contacts with and IO pin to determine it's current state.
