I was wondering if someone can map this out for me on paper, I believe that chip is some sort of relay or possible 555 timer? Buts it's 6 pins and I'm not sure how to look these components up. I'm basically trying to build my own version of this circuit on a breadboard
I know that the bottom 3 solder points are(from left to right) ground then V input then output
