NCP167 not working
Omri284
Joined Apr 18, 2020
21
peterdeco
Joined Oct 8, 2019
484
I'm confused. Why are you connecting a 3.3V regulator to a 3V battery? Regulators are meant to reduce voltage. Attach it to 6V to regulate it down to 3.3V.
Ya’akov
Joined Jan 27, 2019
10,300
As @peterdeco points out, regulators are not boost converters. In fact, they reduce the input voltage by some amount depending on the particular part. So, if you are expecting 3V in to get you 3.3V out, you will be disappinted.
Also, you say “it isn’t working” but you don’t say what that means. While you do have a fundamental problem: insufficient supply voltage, if that wasn’t the case, how would we know where to start helping you?
If you are asking for help with a problem, “I have a problem” is not enough information. You have to go on to say, “…and here are the unexpected or undesirable behaviors I am seeing…”.
Omri284
Joined Apr 18, 2020
21
Ok, it is a boost converter and I get 0V at the output.
The operating input voltage range according to the datasheet is: 1.9 V to 5.5 V
Ya’akov
Joined Jan 27, 2019
10,300
But it’s not a boost converter, it’s a low drop out voltage regulator so you will need at least 3.51V at the input to get your 3.3V part to function. The datasheet is very clear on this.
Ian0
Joined Aug 7, 2020
13,279
Hi, it's a DC-DC boost regulator, raises the voltage up to 3.3V
It's not a boost converter. (If it were, where's the inductor?) Look at this line in the datasheet:
In case you are not familiar with the term "dropout", it means that the INPUT must be at least 450mV GREATER than the OUTPUT for it to work at 1.8V output, or 290mV GREATER than the OUTPUT for it to work at 3.3V output.
