Hello everyone,
I have a 12V relay, here is it datasheet. As I read the datasheet they say that the max voltage allowable for the coil is 130%, which is 15.6V. So if I put a higher voltage to it, then it may break. But how about the N.O pin, is the limitation for the coil apply for the N.O pin or I can or anything else?
Hope you guys can help me! Thank you so much!
