N-Fet driven using TTL
ErnieM
Joined Apr 24, 2011
8,415
Very hard to judge from that graph but it appears the typical voltage with Vgs = 5V and Id = 20 A is around 3 volts, or three times worse.
cmartinez
Joined Jan 17, 2007
8,897
Never mind... I'm convinced that most mosfets out there are designed for full-conduction (if that's the correct term) when at least 10V is applied at the gate.
Since what I'm doing is rather important, I decided to add a DC-DC converter to the circuit, even though it's a little expensive.
On the plus side, said converter outputs power with an isolated ground.
