mystery setup to explain. previous user plugged batteries in a weird way . how to explain it
Irving
Joined Jan 30, 2016
5,195
BUT if that uses an XLR connector, I am not conviced that the current handling rating of the connector is adequate. BUTI have seen folks be very lucky so I don't argue.
The XLR connector is rated at 8A and is the standard charger input on all current wheelchairs using VR2, Qtronix or R-Net control systems and has been for at least 25y+ (other than cheap Chinese ones which are generally proprietary).
circuityes
Joined Jun 20, 2019
39
Apart from the possibility that the previous user was maybe just replicating the manual setup,
Do you guys see advantage to use this setup versus the one from verte(one anderson connector per battery directly to the chair) ?
Irving
Joined Jan 30, 2016
5,195
That harness looks OEM to me, I doubt the original user did anything to it, that's how it arrived. My experience with second-hand wheelchairs is that there are always minor differences compared to the service manuals as they are manufactured in several locations and minor variations occur which are not tracked. Also, I would argue that 99.99% of wheelchair users never open the box, and certainly never change anything from stock.
Personally I see no advantage to having the connectors as opposed to just direct cables. It doesn't make servicing or battery replacement any easier, and the connectors add extra (although minor) resistance, which you don't need.
BTW, what's your interest in wheelchairs? Is it for yourself or someone else?
circuityes
Joined Jun 20, 2019
39
HI I have to use one , i live with chronic pain
Irving
Joined Jan 30, 2016
5,195
Sorry to hear that. I too am totally dependent on my chair being paralyzed from the chest down with limited use of my arms and no hand function after breaking my neck in 3 places, 13y ago. But I can use a keyboard, slowly, and trackball, so I continue to work, design, plan and, with some assistance, build and test.
circuityes
Joined Jun 20, 2019
39
Hi ok so sorry to hear you have paralisis. I can see you are able to do lots of things and you write very well and kindly too.
Thanks
