Mysterious LED
Lucky-Luka
Joined Mar 28, 2019
181
Hi all
I've analyzed an LED taken from a votive candle.
Why is it flickering (they do that to remeber the fire of wax candles)? What's inside of it?
28,266
It looks like there are three components, the largest block being a resistor to limit the LED current, then the LED in the center, followed by a very small IC device which is probably programmed to produce the flicker. That could be as simple as an oscillator or more complex, executing a programmed sequence.
Lucky-Luka
Joined Mar 28, 2019
181
An IC like those in the RGB 2 pins LEDs?
Is there any infos about these kind of LEDs?
I haven't found any.
dl324
Joined Mar 30, 2015
18,465
It's clear from your picture that there's more than just an LED in the package.
I have some LEDs that have multiple colors of LEDs in a standard 5mm package. They flash, dim, and brighten the individual LEDs in a repeating pattern.
Audioguru again
Joined Oct 21, 2019
6,826
There are inexpensive novelty products with a colors-changing LED that either slowly fades between colors or quickly flashes them. I use them to replace the white LED in solar garden lights.
BobTPH
Joined Jun 5, 2013
11,647
I once programmed a micro to mimic those. I used a PWM with 8-bit duty cycle and fed it with a linear feedback RNG to simply set the duty cycle. It looked pretty much the same as the flickering candles.
Bob
