My USB 2.0 to sata adapter does not work and this is the second one i tried!!!??
BlakesterGamer
Joined Apr 20, 2016
92
so i got a USB to sata adapter and it did not work so i returned it and got another one and it still does not work.Can someone plz help me
bertus
Joined Apr 5, 2008
23,041
You give us very less info to go on.
Are you using an USB 2.0 port on the PC?
I have noticed that some devices will not work on USB 3.0 ports.
What operating system are you using?
Are the drivers installed?
Bertus
rthomas12
Joined Dec 6, 2016
32
Can you feel hear or feel the drive spinning? I've used the cables for data recovery on a Pc and no drivers were needed. It should show up as removable media. Data transfer is much shower than pulling the side cover off of a tower Pc and adding the drive to the available connectors.
BlakesterGamer
Joined Apr 20, 2016
92
Bertus
Drivers did not come in the packaging neither did it say were to get them I am using windows 7 and I tried using it with USB 3.0 now that you mentioned that it may not work with USB 3 I will try USB 2.0
BlakesterGamer
Joined Apr 20, 2016
92
Do I have to wipe the hard drive I am using?. Because I think I left Ubuntu on the hard drive but my local pc store can wipe the HDD so should I have them wipe the drive or not?
rthomas12
Joined Dec 6, 2016
32
I'm new to Ubuntu. I do not use it as much as I was hoping to because the Arduino IDE is outdated. Are you trying to recover data from the drive? If you are, you could make a bootable usb stick with Ubuntu on it, boot up any computer and then try your cables.
ClassOfZero
Joined Dec 28, 2016
114
http://www.ext2fsd.com/?cat=3
Usually ext2/3/4 drivers are ok in read mode under windows.
Under linux a simple
dd if=/dev/random of=/device/path bs=512 count=1024
Will wipe the partion table. Should allow you to partition your drive using windows. Mind tho back up any data you want off that drive and really really make sure you have the correct device.
BlakesterGamer
Joined Apr 20, 2016
92
ok I fixed the issue. I was trying to use a desktop drive when the adapter could only supply enough power for a laptop drive so I found a 80GB laptop drive and plugged it in and it works!!!! But THX to every1 who tried helping
