Capacitor Adapter Circuit
iLEEZi
Joined Mar 19, 2026
29
Ive been trying to recreate this circuit on LTSpice but it just doesnt seem to be working. I built it up until IC2 and instead of using the virtual ground set up, I used normal PSU rails for all the Opamps.1773952770201.png
28,266
REmove the unused RC circuits above U3. They do nothing at all. And, in the first image, U1 was probably an LM324.
MrAl
Joined Jun 17, 2014
13,793
yeah i just changed diodes to real ones, yet no change in output. heres the circuit file
It seems to work for me.
Just a small note...
We normally use Vcc for the positive supply, and Vee for the negative supply. Swapping the two may confuse some readers.
iLEEZi
Joined Mar 19, 2026
29
What do you want the circuit to do?
I need a fully rectified square wave at the 1Meg resistor. it seems like i got something similar but i dont understand why the amplitudes half the input square wave. Also im not sure how the rotary switch affects the final output value, because I tested it while connecting to the different modes and still got the same output. It is a circuit that measures the capacitance of an unknown capacitor while the output is connected to a multimeter. The multimeter measures the capacitance in volts.
iLEEZi
Joined Mar 19, 2026
29
Hey there, so the amplitude of the output should be half the input? Also apologies for the incorrect labelling, im new to electronics and LTSpice so im getting used to it slowly, thank you for correction.
iLEEZi
Joined Mar 19, 2026
29
I fully completed the circuit and made changes so that it matches the schematic. However, it seems like the "completed" circuit is not behaving as it should be, and now im unsure what output is expected at the "Output" resistor. I attached the new file of the circuit below, any help is appreciated. Many thanks.
ericgibbs
Joined Jan 29, 2010
21,569
hi Lee,
IC1d output is the Virtual Ground.
E
IC!d job is to divide the 9v battery into two voltages, +4.5v and -4.5V with its out put at a virtual Zero volts
iLEEZi
Joined Mar 19, 2026
29
hi Lee,
E
oh that makes sense, but ltspice is not letting me simulate it without a ground, i also added the missing line you mentioned, yet no change. Apologies, I am begineer at this since im a first year student.
