I do the same, or strategically located test-points (for a bed-of-nails), on my boards for in-production programming and testing.Image #1, top-left corner. I am SO gonna steal that connector placement trick.
ak
It's possible to be both.It is actually electrolyte leakage. I removed a couple and the capacitance value had dropped to almost zero.
Electrolyte leakage is a common occurrence when operating with applied voltage, high ripple current AND most importantly, elevated temperature for long periods of time.
I had mentioned earlier that the garage this equipment was located can be 115F in the summer. And the equipment operated for over 13 years.
Also, searching on the web, it appears that this is a common failure mechanism for this model.
Defective Chinese and Taiwanese capacitors—widely known as the "capacitor plague"—refer to a historical wave of premature aluminum electrolytic capacitor failures that occurred roughly between 1999 and 2007, alongside lingering quality issues in some modern cheap electronic components.
Causes of Failure
- Stolen and Incomplete Formula: The crisis famously stemmed from industrial espionage where an incomplete, water-based electrolyte formula was stolen from a Japanese company and sold to various start-up and Taiwanese/Chinese manufacturers. [1]
Signs and Symptoms
- Bulging or "Mushroom" Tops: The top vents of the metal can push upward or round out due to internal gas pressure.
- Leaking Fluid: Crusty residue, glistening brown/clear oil, or dried electrolyte leaking from the top or bottom rubber bung.
- Sudden Device Failure: Unexplained motherboard crashes, short-cycling, boot loops, or complete power supply failure in electronics from that era (like PCs, early Xbox consoles, and displays).
Last century, definitely. But the all-tantalum-all-the-time days ended in the 80's. Today - not so much.Military uses tantalum caps and never electrolytics for endurance.
