My multimeter just got destroyed - What happened?
alchemizt
Joined Mar 23, 2021
34
I'm new to electronics, I'm guessing I did something stupid but I don't know what yet. I bought a second hand 12V transformer today from an electronics scrapyard, the guy selling it tested it in front of me with his multimeter and it output 12V.
I was excited to test it out myself when I got home, so I connected a power cord to the two blue wires and connected to two green wires to my multimeters probes, then I went to plug in the power cord and a bolt of lightning came out of the electrical outlet, the multimeter lit up then died. Some smoke came from something but I couldnt see what.
What exactly happened? I thought multimeters can handle high voltages so how could 12V output destroy it like that? Its possible the probes might have been too close together, would that explain the lightning bolt from the outlet? Does this mean the transformer is likely damaged now too?
An additional question:
Do AC transformers have a direction in which you need to hook them up? In other words, could it be I should have hooked the power supply up to the green wires instead of the blue wires?
dl324
Joined Mar 30, 2015
18,524
Until you get more experience, you should not connect anything to line voltage without a fuse.
We can't tell you exactly unless you can tell us exactly what you did.
What setting did you have your meter? If you had it on DC or AC volts, the meter wouldn't be damaged (unless you had it on the wrong scale). If you had it on Amps, that would blow the fuse, but the meter should be otherwise undamaged. If you had it on Resistance, that scale is dead and may have taken others with it.
If you shorted the transformer secondary and didn't have a fuse on the primary, sparks might be possible.
It depends. Did you have a fuse on the primary? Was the short removed quickly? Did any smoke come out of the transformer?
You don't mention your region or line voltage. With a 12VAC secondary, it's either a 10:1 or 20:1 stepdown. You can't swap the primary and secondary wires. If you do, you'll generate some lethal voltages and might break down the insulation on the wires.
If you're connecting multiple secondaries in series or parallel, there is a polarity you need to be mindful of.
alchemizt
Joined Mar 23, 2021
34
It was on 200V AC. The mains is 220V. Some smoke came out of something, not sure if it was the transformer or the multimeter. The short was removed really quickly, I didn't actually plug it in, the sparks came when I got close so I instinctively backed away. I didn't put any fuse in no. I need to learn how to do that.
So its possible I hooked it up the wrong way and turned it into a step up transformer. How can you tell which wires on a transformer are for input and which are for output? I see that this is potentially very dangerous so Im going to take your advice and never experiment with lines voltage without a fuse.
alchemizt
Joined Mar 23, 2021
34
It looks like I hooked it up the wrong way and stepped up the voltage. Do some of these transformers come with fuses built in and some don't? I have a brand new 220V to 30V transformer which doesn't seem to work at all, would mean it has a fuse thats blown? I attached a picture of this transformer.
Is there a way to easily open these kinds of transformers and see if it has a fuse?
SamR
Joined Mar 19, 2019
5,549
No, but if your meter still worked you could check the winding for resistance to see if they had shorted or opened. Glad you didn't get hurt. Next time check the xfmr with a battery...
DickCappels
Joined Aug 21, 2008
10,661
Do this with an external fuse in an insulated fuse holder:
Technically, transformers have a polarity but that is "erased and re-written" every power cycle, and in the case of small transformers like the ones we are discussing the memory (hysteresis) should have little effect.
SamR
Joined Mar 19, 2019
5,549
You can use a battery to check the conductivity of a winding to see if it is open, but it takes AC to check the primary to secondary turns ratio. Feeding 12VAC into the primary of a 120VAC to 12VAC transformer will put ~1V on the secondary for example. Your meter actually uses a battery to measure resistance.
dl324
Joined Mar 30, 2015
18,524
I think I recall reading about or seeing a transformer with an integral fuse. But they would be the exceptional case, not the norm. Manufacturers expect anyone using a transformer to know how to do so safely. You don't have enough experience to be working with line voltage and transformers.
If I ever have the slightest doubt about which winding is the primary, I connect it to the secondary of a low voltage transformer (like 6.3VAC) so things don't get out of hand.
Use a meter to check winding resistance. If it's opened, either the winding opened or there's a fuse. If you take the transformer apart, be prepared for the possibility that it will be unusable if reassembled.
BobTPH
Joined Jun 5, 2013
11,678
The primary of s step down transformer will generally use thinner wire than the secondary. If you connected the one with thicker wire to 220V it was backwards and disastrous.
Bob
35,320
Also, you can measure the DC resistance of the windings.
Generally, the primary winding will be about 100-500 ohms. The secondary for a LV step-down transformer will show very low resistance, less than 10 ohms. The secondary winding uses lower number of turns of thicker wire.
alchemizt
Joined Mar 23, 2021
34
Bob
I thought this too but I asked the lady at the shop to test my new 30V transformer and she connected 220V the two bigger wires and connected the smaller wires to her multimeter and it output a low voltage.
38,952
How do you check a transformer with a battery?
To check the turns ratio you would need an oscilloscope.
You momentarily connect a small battery (e.g. 1.5V AA alkaline) across one of the windings and observe the peak output of the other winding(s).
The relative voltage compared to the battery voltage will tell you the approximate turns ratio.
Jon Chandler
Joined Jun 12, 2008
1,660
I suspect that someone who doesn't know there's a difference between input and output of a transformer will not have a handy o'scope, nor understand this method.
Irving
Joined Jan 30, 2016
5,195
Post a picture of the 12v transformer. There won't be a fuse in that transformer, its a low-end product. On the 30v transformer you have, the green wires are definitely the output, but it doesn't follow that the green wires on the 12v one are the output, the colours are not representative.
The transformer is almost certainly fried! I'm guessing the blue wires are (were) the output - that winding is now probably open-circuit. The primary winding almost certainly has shorted turns where the 4000v AC generated has punctured the insulation.
Carry on like that and you'll win a Darwin award!
alchemizt
Joined Mar 23, 2021
34
How did you know that the green wires are the output? Has it something to do with being on the same side as the brown wire? What is the brown wire for BTW?
Irving
Joined Jan 30, 2016
5,195
The thicker solid-core wires are invariably the secondary, the brown wire is almost always a centre tap, so a 30v secondary is actually 15v-0-15v and can be used to give 20v DC with 2 diodes rather than a bridge rectifier.
