My latching circuit starts in an unexpected state
magic_blue_smoke
Joined Dec 19, 2020
I've built this circuit with soft-latching on and off buttons, and I have two main questions:
https://www.falstad.com/circuit/cir...AADIGgCCABEN9rylW6RP99wAIoAVQAogBlAAqAEknYwgA
The circuit is meant to one that latches on when the 'on' momentary switch is pressed, and which would then power a microcontroller. The microcontroller would be able to turn the power off when it has finished its work. For now, I have modelled the microcontroller as a simple LED with resistor, and I have modelled the off signal with another momentary switch.
The momentary switches should work interactively in the linked version.
Question 1 is:
In the simulation, the circuit is initially 'off'. But when in real life when I built the circuit on breadboard, it seems to start in an 'on' state. Is there a modification I can/should make to have it start in an 'off' state? I already pull the base of the PNP up to vcc which I thought should do the trick.
The on/off buttons do work as expected, which is enough for my use case. I'm just curious/interested.
Question 2 is:
If the 'on' momentary switch is pressed and held down, I can see that current passes through the base of the NPN transistor and out of the collector. I have marked this on my circuit with the label 'QUESTION'.
Is this bad? I could stop this from happening by replacing that labelled wire with a diode, but my question is whether that's something that I should do, or is it okay to leave it as it is?
It might be useful to point out that I'm just a beginner.
eetech00
Joined Jun 8, 2013
4,724
Question 1 is:
Change the pull-up resistor to about 10x the base resistor, so if base is 3.3k, pullup should be 33k.
Question 2 is:
Add pull down to base of the "off" NPN so it doesn't "float". This ensures the NPN is "off". So if base is 3.3k, pullup should be 33k.
38,787
A small capacitor (e.g. 100nF) from the left NPN base connection to ground (please label the parts on the schematic) should also help.
