Pulse Latching Circuit
moonlystar1111
Joined Feb 1, 2024
106
I'm working on a project where I have a pulse that stays high for a certain duration, as shown in the figure below. What I need is a circuit or IC that can maintain this high pulse continuously until I press a reset button (or apply another control signal like OV or 5V).
In short, the pulse should stay high indefinitely until the reset condition is triggered.
Can anyone suggest a circuit design or IC that can latch the pulse in this way? Any guidance or recommendations would be highly appreciated!
Looking forward to your thoughts and suggestions!
sghioto
Joined Dec 31, 2017
8,758
What will this High output pulse be connected to?
Should this High output pulse be at the same voltage level as the trigger pulse?
What supply voltages are available?
One suggestion:
boostbuck
Joined Oct 5, 2017
1,067
The sample circuit you show should work as you want it to if you connect the SCR and its load across a dc supply - the SCR will then remain conducting until the load current is interrupted.
28,515
That original circuit looks like a GFI (ground fault interrupter) and those devices do a solid hard latch that requires a mechanical reset.
SO I am suggesting that the TS needs to provide a lot more detail about the application before any more suggestions, because a GFI system is potentially a "LIFE CRITICAL SYSTEM"!!!
moonlystar1111
Joined Feb 1, 2024
106
One suggestion:
The high output pulse will be connected to gate of scr.
Yes this high pulse should be at same voltage level.
Supply voltages are 5vdc, 20 vdc and 120vac.
Thanks for your suggestion with 555 timer. I think jk flip flop will also be used to reduce the circuit.
28,515
It still does not make much sense to me, WHAT are you trying to accomplish?? And the circuit still looks like a ground fault interrupter. SO just what is the goal?????
