The thread seems to have drifted away from finding the fault. If the blue LED is lit (At it's normal brightness.) Then there must be an output from the power supply. The led in series with a 39K resistor (RS3) is connected across the input side of the common mode filter on the DC output. It is VERY unlikely that either of the two windings on the filter have become open circuit. Measure the voltage between the two solder pads where the output wires are connected. If you don't get a reading close to 20 volts then measure the voltage at the input side of the output filter. (This filter is the toroidal inductor close to the output connections.)
Les.
Les.
