My first try at Fm transmitter
be80be
Joined Jul 5, 2008
2,396
Well it looks to work I looked at it with my scope you can see the modulation
But I think I have to find a better transistor I didn't have a 2SC2001.
But with the scope I can see the modulation when I talk.
I was thinking I have a SDR maybe i can figure where it at on the FM band with it I don't have a FM radio no more lol.
Dodgydave
Joined Jun 22, 2012
11,395
Have you got an FM radio on your mobile phone?
be80be
Joined Jul 5, 2008
2,396
Here a short video of what the scope showing on the output with me tapping on the mic i think i'm nowhere near the FM band tho.
Ian Rogers
Joined Dec 12, 2012
1,136
Hey Burt! Haven't I seen the circuit somewhere before!! Ah yes Back to the future ( on Doc's head LOL!! )
Last one I built was AudioGuru's FM transmitter... ( Shown somewhere on another forum ).... It worked great.. I used it for the kids to talk through the radio!!
DickCappels
Joined Aug 21, 2008
10,661
The bandwidth of your scope is 25 MHz which might mean it is insensitive to signals around 100 MHz. What you see is the baseband microphone signal because the transistor is an emitter follower that passes the microphone signal through at near unity gain.
It will be interesting to see what you get with your SDR tuner.
Audioguru
Joined Dec 20, 2007
11,248
It will not work with a condenser mic that needs a 48V power supply. But it will work with an electret mic that has the needed 48V embedded in its electret material.
It will have these problems that I fixed when I designed my FM transmitter:
1) Its radio frequency changes when something moves towards or away from it or its antenna. Therefore I added a buffer transistor at its output to isolate its radio oscillator from capacitance changes at its antenna.
2) Its audio level and radio frequency change as its battery runs down. Therefore I added a low dropout voltage regulator.
3) Its audio level is faint because it needs a preamp that mine has.
It sounds muffled because it is missing the pre-emphasis that mine has and all FM radio stations have.
You will not be able to see FM modulation on a 'scope because the frequency change is extremely small. This transmitter transmits AM and FM at the same time. You will see loud amplitude changes (AM).
