My first schematic of a 2-channel relay board
panic mode
Joined Oct 10, 2011
5,469
R1 and R2 are used to limit current through LEDs that are part of the optocouplers.
If using optos, put those back where they were. 1k is good enough for the base. adding 220 Ohm will not change anything there
StealthRT
Joined Mar 20, 2009
317
Alright thank you @dendad for all your help!
Final schematic:
1) Removed LTV-356T Opto.
2) Added 10k between Base and Emitter of the PMBT3904.
3) Connected LED to 5v line instead of the collector line on the PMBT3904.
4) Replaced 200R with 220R.
5) Replaced normal fuses for blade fuse holders.
6) Replaced 18v G5LE-1 relay with the correct 5v relay G5LE-1A4 DC5 model.
7) Added a solder pad for the always on (AO) +12v line.
MaxHeadRoom
Joined Jul 18, 2013
30,885
Every pin that is deemed a power input, requires a source identified by a power flag, the exception is usually any device that supplies it with its relevant pin, identified as power out.
As in a 3pin regulator IC for example, 7805 etc.
