Must Ground Plane Connect Directly Under Antenna?
johnyradio
Joined Oct 26, 2012
615
In this proximity coupled antenna, is it necessary to solder a ground connection directly beneath the antenna? Or can the ground plane be connected to ground point elsewhere on the ground plane, far away from the antenna?
Assume the patch substrate and ground plane are several wavelengths larger than the patch.
