Music that makes you smile
LowQCab
Joined Nov 6, 2012
5,102
I prefer the "AniMusic" version .....
They've got mostly original stuff, 2-Albums worth, very artistic.
Their stuff is very much worth watching fullscreen with a good sound-system.
My old SL-5 needs a little TLC. It plays fine but I should replace the old cartridge, stylus and check the electronics/mechanical parts for wear. If you have one or a similar Technics model, this is a great refurb series.
LowQCab
Joined Nov 6, 2012
5,102
I haven't had a Turntable since the late '80's,
but I grew-up in a house where my Dad's CRANKING-UP of Classical-Music-Records on every Sunday
was to be expected, and if You didn't like it You could go somewhere else.
So, I learned all of the major "works", note by note, by the time I was around ~12-years old,
including "Pictures at an Exhibition".
Then I found-out about Led-Zeppelin, and a lot of other excellent Music,
which, of course, I could only listen to on Headphones, ( if You want to listen to that kind of crap )..
He had an Acoustics-Research Belt-Drive-Turntable along with a home-made Preamp which had
Metal-Can packaged "Integrated-Circuits" ( !!!!! cool stuff !!!!! ) and
an "Allied" FM-only-Tuner, and a home-made Tube-Power-Amp that
probably weighed close to ~75 pounds,
with four ~8-inch cubed, hermetically-sealed, Transformers, ( mostly Military-Surplus parts ),
which put-off enough heat to keep the whole Living-Room warm in the winter,
( and which was replaced by a home-built Transistor-Amp around ~1974 ),
all driving a pair of home-made "Acoustic-Suspension" Speaker-Cabinets with "Goodman" 15" drivers.
Supposedly top-notch stuff for circa~1967, and this setup would seriously shake the whole House.
I've always had a turntable with every audio/media system I've designed and built because I have all of my old records and play them regularly when working on various projects.
I can set the system to 'pure direct' and have the best of 2 channel source in a room designed for 11.2 ATMOS. You don't need fancy tone controls if the 'room' is tuned.
https://manuals.denon.com/AVRX3800H/NA/EN/GFNFSYuttunruh.php
Prewire for multichannel sound and lots of extra insulation and damping panels for passive sound control and the reduction of room modes for flat bass response and echo reduction.
