Multiplication and BCD conversion routines for the PIC16LF1823
MrSalts
Joined Apr 2, 2020
2,767
No. I am just pointing out that Ya'akov is a good man and a person of high integrity.
Good to know you randomly decided to point out the Ya'akov is a good man by using a Yiddish word on a thread where he is not participating. Let's get back to PIC16LF1823.
cmartinez
Joined Jan 17, 2007
8,857
Have you checked out the usual PicList site routines?
Yes I have. And most of the code I found is either uncommented or of no use to me because it's been written for a different architecture.
Anyway. I'd like to write the code myself so that in the end I can have a thorough understanding of how it works and its intrinsic limitations.
30,810
OK, There is also Pic AN-526 that might help the assembly code process unless already have it.
35,180
Now that we have shown you the Top-Down Design, let us look at the Bottom-Up Implementation.
I am going to use PB's approach because it is going to be faster when working with small multipliers.
There are 5 functions that you will need to implement. Do not use subroutine calls as this will require extra cycles. Use in-line coding instead.
The objective is: R <= M x N
where,
R is 48-bit result
M is 24-bit multiplier
N is 48-bit multiplicand
Note that we make N = (n5, n4, n3, n2, n1, n0)
You can start with N = 0 and only initialize (n2, n1, n0) with a 24-bit multiplicand.
Here are the 5 functions you need:
48-bit addition
R <= R + N
48-bit Left Shift
N <= N << 1
24-bit Right Shift
M <= M >> 1
Test LSB of M
is LSB of M equal to 1?
Test if M is zero
is M = 0?
Once you have code for these five operations the full multiplication should be straight forward.
22,111
where,
R is 48-bit result
48-bit addition
R <= R + N
48-bit Left Shift
N <= N << 1
24-bit Right Shift
M <= M >> 1
Test LSB of M
Test if M is zero
is M = 0?
Don't forget to initialize R to zero before the first R <= R + N operation
BobaMosfet
Joined Jul 1, 2009
2,211
I know how to do the multiplication by "brute force" using a 6-byte accumulator, a 6-byte multiplicand shift register, and a 3-byte multiplier shift register. I don't know the details of any more efficient multiplication algorithms.
  1. Clear the Accumulator
  2. Repeat steps 3-6 24 times, goto 7
  3. Test the LSB of the multiplier, if it is a 1, add the multiplicand register to the accumulator
  4. Shift the multiplicand register left 1 bit
  5. Shift the multiplier right 1 bit
  6. If the multiplier is equal to 0, then DONE, else goto 3.
  7. DONE
To convert 6 ASCII digits belonging to the set [0-9], you clear a 3 byte shift register. Then you start with the most significant byte, subtract '0' and OR that into the least significant byte of a 3-byte shift register. Shift the 3 byte shift register to the left by 4 bits. Repeat for the remining 5 characters.
This takes me back... writing my own mult and div routines in assembly for 3D robotics simulators in reactor cores. We had to create a visual 3D simulator (this was well before 3D games) to test fuel-handling tapes in nuclear reactors prior to actually doing the operations to prove the paper-tapes were valid and would not get the grapple-head stuck with a block attached in an open core.
22,111
Sounds like there was a premium on getting it right each time, every time. There were no points for 2nd place.
cmartinez
Joined Jan 17, 2007
8,857
3.- Test the LSB of the multiplier, if it is a 1, add the multiplicand register to the accumulator
Papabravo, one question. In step 3, what happens if the LSb of the multiplier is a 0? Should the algorithm execute step 4 immediately? Does that mean that step 4 will always be executed?
Edit: for clear syntax reasons (at least for me) I always make a distinction between LSB and LSb ... one's for Byte and the other is for bit. :)
35,180
What you are computing is
R <= R + N x m
where m is the LSB, least significant bit.
m has a value of 0 or 1.
If m is 0 there is nothing to add.
If m is 1, you add N to R and put the result in R.
Then you go to the next step.
cmartinez
Joined Jan 17, 2007
8,857
R <= R + N x m
Thanks, I get it now ... I was a little confused with your notation. I would've written the algorithm rather as:
R ← R + N · m​
cmartinez
Joined Jan 17, 2007
8,857
Well, a promise is a promise and here's my code.
The code is written rather for the PIC16LF1825, which is identical to the PIC16LF1823 but has much more RAM instead. And it's written to work on Memory Bank 12, but it can very easily be edited to work in any other bank. A bonus, unused routine in the multiplication process is included. That is the subtraction routine.
The more seasoned programmers of this forum are going to have to forgive my clumsy techniques, since my experience with this architecture so far is a little limited; my real expertise being the 8051 family of MCUs.
Also, after writing the code it has become clear to me how to convert HEX to BCD with a simple and direct algorithm that makes use of some of the same routines shown below. But I'll leave it to the future members of this place to try and learn how's its done.
Word of advice, the code compiles perfectly without reporting any errors, but I have not tested it yet. After testing, if I find any errors I'll come back and edit and correct this same post to make sure that there's only one and correct version of the code.
Any comments pertaining this code will be thoroughly appreciated, especially if a bug is found or if a way to make things faster or more efficient is described. Speaking of which, @MrChips is there an advantage to the Bottom-Up implementation that you described vs Papabravo's Top-Down version?
25 JUN 2022, 4:04:51 PM: I have tested the code, and found a few bugs that have been fixed. To the best of my abilities, the code is now fully functional
Code:
;                                   Macro definitions
MovLf macro Literal, File           ;Move a literal value into a file (register)
         movlw Literal              ;it's important to select the proper memory
         movwf File                 ;bank before using this macro
       endm
MovF2F macro FileSource, FileDest   ;Move a file into another file, using w as a mediator
         movf FileSource, w
         movwf FileDest
       endm
;                               End of Macro definitions
;********************************** Zone of common RAM ***********************************
;  Only 16 bytes are available, but there's no need to switch memory Banks to work on it
; available addresses are 70H-7FH
PUSH01             EQU 74H
PUSH02             EQU 75H
GPT00              EQU 76H
GPT01              EQU 77H
GPT02              EQU 78H
CNT00              EQU 79H
NUMBER             EQU 7DH
; The following arrays of 8 bytes will be used in 64 bit math calculations and are located
;                                  in memory Bank 12
A0         EQU 0xA0
A1         EQU 0xA1
A2         EQU 0xA2
A3         EQU 0xA3
A4         EQU 0xA4
A5         EQU 0xA5
A6         EQU 0xA6
A7         EQU 0xA7
B0         EQU 0xA8
B1         EQU 0xA9
B2         EQU 0xAA
B3         EQU 0xAB
B4         EQU 0xAC
B5         EQU 0xAD
B6         EQU 0xAE
B7         EQU 0xAF
C0         EQU 0xB0
C1         EQU 0xB1
C2         EQU 0xB2
C3         EQU 0xB3
C4         EQU 0xB4
C5         EQU 0xB5
C6         EQU 0xB6
C7         EQU 0xB7
D0         EQU 0xB8
D1         EQU 0xB9
D2         EQU 0xBA
D3         EQU 0xBB
D4         EQU 0xBC
D5         EQU 0xBD
D6         EQU 0xBE
D7         EQU 0xBF
; Multiply two arrays whose LSB is pointed at by GPT00 and GPT01, and leave the result in
; GPT02. The GPT02 array must be cleared prior to calling this function
; The size of GPT02 should be the total size in bytes of GPT00 and GPT01. For this purpose
; we will set a size of NUMBER = 8 for GPT02. And the same size for GPT00 and GPT01, but
; their combined values should always fit in 8 bytes or less. This means that at least
; the upper 8 bytes in both GPT00 and GPT01 combined must be set as zeroes.
; This algorithm stops when one of the arrays becomes zero during the process.
; This function works in memory Bank 1 and does not switch active banks during its
; execution
; This function uses Papabravo's algorithm shown at:
; https://forum.allaboutcircuits.com/threads/multiplication-and-bcd-conversion-routines-for-the-pic16lf1823.187336/post-1738564
;   1.- Clear the Accumulator (GPT02)
;   2.- Test the LSB of GPT01, if it's set, then add GPT00 to GPT02
;   3.- Shift GPT01 right 1 bit
;   4.- Shift GPT00 left 1 bit
;   5.- If GPT01 is equal to 0, then DONE, else goto 2.
;   6.- DONE
; GPT02 MUST BE CLEARED prior to calling this function
Multiply_GPT00_by_GPT01:
      MovLf 0x00, FSR0H            ;set FSR0H and FSR1H adresses as that of memory Bank 0 and 1
      MovLf 0x00, FSR1H
      MovLf 0x01, CNT00            ;number of bits to shift the arrays
Multiply_GPT00_by_GPT01_Loop:
        MovF2F GPT01, FSR0L        ;make FSR0 point to the array pointed at by GPT01
        btfsc INDF0, d'0'          ;Test the LSB of array pointed at by GPT01
         call Add_GPT00_To_GPT02   ;if it's set, then add GPT00 to GPT02
        call Shift_GPT01_Right     ;shift GPT01 one bit to the right
        call Shift_GPT00_Left      ;shift GPT00 one bit to the left
        call Is_GPT01_Zero         ;test if the array pointed at by GPT01 is all zeroes
       btfss STATUS, Z             ;test the result reported by Is_GPT01_Zero
      goto Multiply_GPT00_by_GPT01_Loop ;keep going if GPT01 is not zero
    return
;                        Clear Arrays A, B, C, D, and BCD in Bank 1
;                     W, STATUS, NUMBER, PUSH01 and FSR0 are destroyed
Clear_All_Arrays:
     MovLf 0x00, FSR0H   ;FSR0H adress of memory Bank 0 and 1
     MovLf d'36', NUMBER ;arrays A, B, C and D are all consecutive and
                         ;are 8 byte long each, the BCD array is
     movlw 0xA0          ;consecutive to array D and is 4 bytes long
     call Clear_Array
    return
;    Clear an array with NUMBER of bytes starting at location pointed at by W upwards
;   This routine does not change the active bank
;                       W, STATUS, PUSH01 and FSR0 are destroyed
Clear_Array:
     ;Warning, the value of FSR0H must be set prior to calling this function to set
     ;the memory bank in which it will work
     movwf FSR0L                  ;copy W into FSR0L
     MovF2F NUMBER, PUSH01        ;both NUMBER and PUSH01 are located in common RAM
Clear_Array_Loop:
       clrf INDF0                 ;clear register pointed at by FSR0
       incf FSR0L, f              ;point to the next register upwards
      decfsz PUSH01, f
     goto Clear_Array_Loop
    return
;  Test if the array whose LSB is pointed at by GPT01 with NUMBER bytes is all zeroes
; The Zero bit in the STATUS register will be either set or cleared as a result of this
; function. This routine does not change the active bank
;                   Destroyed registers: W, STATUS, PUSH01, FSR0
Is_GPT01_Zero:
     MovF2F NUMBER, PUSH01        ;load NUMBER into PUSH01
Is_GPT01_Zero_Loop:
      movf INDF0, f               ;test if the byte pointed at by FSR0 is zero
      btfss STATUS, Z             ;if it is not zero, then
       goto Exit_Is_GPT01_Zero    ;exit this routine immediately
      incf FSR0L, f               ;otherwise, point to the next byte in the array
      decfsz PUSH01, f            ;decrement the counter
     goto Is_GPT01_Zero_Loop      ;and test again
     ;To get here, an INCF instruction was executed AFTER testing the Zero bit in the
     ;STATUS register. And since INCF affects said bit, it means that we are going to have
     ;to set the Zero bit manually before exiting
     bsf STATUS, Z
Exit_Is_GPT01_Zero:
    return
;  Shift an array to the RIGHT at LSB location pointed at by GPT01, with NUMBER of bytes,
; by CNT00 number of bits. This routine does not change the active bank
;  NUMBER cannot be so large as to exeed the designated memory bank size when added with
; W, or the FSR0 might point outside of said bank
;  This routine does not change the active memory bank
;  Destroyed registers: W, FSR0, STATUS, PUSH01, PUSH02 (the last three are in common RAM)
Shift_GPT01_Right:
     MovF2F CNT00, PUSH02
Shift_GPT01_Right_Loop_00:
       movf GPT01, w
       addwf NUMBER, w
       movwf FSR0L                ;FSR0 now points to the MSB of the array
       decf FSR0L, f              ;necessary to make sure FSR0L points to MSB after adding
       MovF2F NUMBER, PUSH01      ;both NUMBER and PUSH01 are in common RAM
       bcf STATUS, C              ;clear the carry flag before beginning the shifting
Shift_GPT01_Right_Loop_01:        ;of NUMBER bytes
         rrf INDF0, f             ;rotate right the register pointed at by INDF0 through C
         decf FSR0L, f            ;point to the next register down
        decfsz PUSH01, f
       goto Shift_GPT01_Right_Loop_01
      decfsz PUSH02, f            ;shift the next bit
     goto Shift_GPT01_Right_Loop_00
    return
;  Shift an array to the LEFT at LSB location pointed at by GPT00, with NUMBER of bytes,
; by CNT00 number of bits. This routine does not change the active bank.
;  NUMBER cannot be so large as to exceed the designated memory bank size when added with
Shift_GPT00_Left:
Shift_GPT00_Left_Loop_00:
       MovF2F GPT00, FSR0L        ;FSR0 now points to the LSB of the array
Shift_GPT00_Left_Loop_01:         ;of NUMBER bytes
         rlf INDF0, f             ;rotate Left the register pointed at by INDF0 through C
        decfsz PUSH01, f
       goto Shift_GPT00_Left_Loop_01
      decfsz PUSH02, f
     goto Shift_GPT00_Left_Loop_00
    return
;  Add two HEX arrays at LSB location pointed at by GPT00 and GPT02 correspondigly,
; with NUMBER of bytes each, and store the result in the same array pointed at by GPT02.
; The result will have the same NUMBER of bytes as the added arrays, and therefore this
; routine will not be able to handle an overflow. GPT00, GPT02 and NUMBER are all
; located in common RAM
;  This routine does not change the active Bank
;  Destroyed registers: W, FSR0, FSR1, PUSH01, STATUS
Add_GPT00_To_GPT02:
     ;Warning, the values of FSR0H and FSR1H must be set prior to calling this function
     ;to set the memory banks in which it will work
     MovF2F NUMBER, PUSH01        ;preserve the value of NUMBER
     MovF2F GPT00, FSR0L          ;Prepare both FSR0 and FSR1 pointers
     MovF2F GPT02, FSR1L
     bcf STATUS, C                ;clear the carry flag before proceeding
Add_GPT00_To_GPT02_Loop:
       movf INDF0, w              ;add both bytes along with the carry flag, and
       addwfc INDF1, f            ;store the result in register pointed at by FSR1 (GPT02)
       incf FSR0L, f              ;increment pointers to the next byte up in the arrays
       incf FSR1L, f              ;the Carry Flag is not affected by this operation
      decfsz PUSH01, f            ;continue loop, the carry flag is not affected
     goto Add_GPT00_To_GPT02_Loop
    return
;  Subtract two HEX arrays at LSB location pointed at by GPT00 and GPT01 correspondigly,
; with NUMBER of bytes each, and store the result in the same array pointed at by GPT01.
;  The formal operation is GPT01 <- GPT01 - GPT00
; routine will not be able to handle an underflow. GPT00, GPT01 and NUMBER are all
;  In the end, if the result of the operation was a negative number, the Carry flag will
; be reported as set
Subtract_GPT00_from_GPT01:
     ;to set the memory bank in which it will work
     MovF2F NUMBER, PUSH01        ;use PUSH01 so as to preserve the value of NUMBER
     MovF2F GPT01, FSR1L
     bsf STATUS, C                ;SET the carry flag before proceeding!
Subtract_GPT00_from_GPT01_Loop:
       movf INDF0, w              ;subtract GPT00 from GPT01 along with the carry flag,
       subwfb INDF1, f            ;and store the result in GPT01
       incf FSR0L, f              ;increment pointers to the next byte down in the arrays
     goto Subtract_GPT00_from_GPT01_Loop
    return
35,180
In Engineering Design we use Top-Down Design and Bottom-Up Implementation in the same project.
The purpose of Top-Down Design is to identify the problem and to examine the big picture without a need to look at the details.
Bottom-Up Implementation allows us to focus on the specific details of one part of the problem one at a time without being bogged down with too much baggage.
Top-Down Design comes first. This is the brain-storming stage.
Bottom-Up Implementation comes at the getting-down-and-dirty stage.
cmartinez
Joined Jan 17, 2007
8,857
Quick question, are these two instructions equivalent?
Instruction A: moviw 0[FSR0]​
Instruction B: movf INDF0, w​
cmartinez
Joined Jan 17, 2007
8,857
I have tested the code, and found a few bugs that have been fixed. To the best of my abilities, I can say that the code is now fully functional.
I've also written and tested an Hex to BCD conversion routine and have verified that it works perfectly. But I'm not going to give it away just like that. This is a learning place, not a code repository, after all. Suffice it to say that said routine can much more easily be written by making use of the code I posted above.
Thanks all who helped and contributed to this thread.
cmartinez
Joined Jan 17, 2007
8,857
Ah ... division, division, division ... whether it be math, or politics ... the world is ruled by division ... I hate division.
1657660552869.png​
I guess that, at least for me, writing a freaking division algorithm for the PIC16 architecture was inevitable ... just like Thanos. I know that my computer's CPU contains a table that allows it to compute division operations much faster, but I can't afford the space that such a table would take in my puny MCU. So I'm gonna have to go at it step by step.
Anyway, here's my one and personal algorithm for division with an arbitrary number of bits. I've already tested it "by hand" using an Excel worksheet, and it seems to work fine. If anyone knows a more efficient way of accomplishing this task, I'd be more than happy to consider it.
Code:
1.- Set quotient to 0, counter to 0
2.- Is the divisor less than the dividend?
    Yes:
      - Shift the divisor one bit to the left
      - Increment the counter
      - Goto step 2
3.- No, the divisor is equal to the dividend:
      - Subtract the divisor from the dividend
      - Set bit(counter) in the quotient
      - Goto step 4
    No, the divisor is greater than the dividend:
      - If counter = 0, goto step 4
      - Shift the divisor one bit to the right
      - Decrement the counter
        Yes:
          - Set bit(counter) of the quotient
          - Goto step 2
         No:
          - Goto step 3
4.- We're done, the result is contained in the quotient, and the remainder in the dividend
djsfantasi
Joined Apr 11, 2010
9,237
I once knew a method similar to CMartinez; perhaps it’s the same. But here it is using shifts, bitwise operators and subtraction. I found it again here.
Multiply/Divide Routines:
unsigned int bmult(unsigned int x, unsigned int y)
    int total = 0;
    int i;
    /* if the i-th bit is non-zero, add 'x' to total */
    /* Multiple total by 2 each step */
    for(i = 32 ; i >= 0 ; i--)
        total <<= 1;
        if( (y & (1 << i)) >> i )
            total = badd(total, x);
    return total;
unsigned int bdiv(unsigned int dividend, unsigned int divisor)
    int i, quotient = 0, remainder = 0;
    if(divisor == 0) { printf("div by zero\n"); return 0; }
    for(i = 31 ; i >= 0 ; i--)
        quotient <<= 1;
        remainder <<= 1;
        remainder |= (dividend & (1 << i)) >> i;
        if(remainder >= divisor)
            remainder = bsub(remainder, divisor);
            quotient |= 1;
    return quotient;
cmartinez
Joined Jan 17, 2007
8,857
Here's a dumb question:
How do I set bit XX in file FF ?
Say:
Code:
  XX EQU 0x70  ;both registers located in common ram
  FF EQU 0x71
  movlw d'3'
  movwf XX
  bsf FF, XX
The problem with the previous example, is that since XX EQU 0x070 (binary 0111 0000), it will be bit zero which will be set, not bit 3 as I want, because the bsf is expecting a literal that defines the bit number, not a file. I realized this when I read a warning from the compiler stating that only the three lower bits of the defined value would be used in the instruction.
35,180
If you have mastered multiplication then division should fall into place. It is the reverse process.
I wouldn't give the exact details but it goes like this.
There are four terms:
dividend / divisor → quotient, remainder
Suppose you have a 16-bit dividend and 16-bit divisor.
Start with a 32-bit register [R1, R0] divided by [divisor].
[quotient = 0]
[ R1 = 0 ][ R0 = dividend]
[divisor]
Shift [R1, R0] 1 bit to the left.
Compare [R1] with [divisor]
if [R1] >= [divisor] then subtract [divisor] from [R1] and left shift 1 into the quotient, else left shift 0
repeat this 16 times (it could be 17 times, I would have to check this).
cmartinez
Joined Jan 17, 2007
8,857
Say:
Code:
  FF EQU 0x71
  movlw d'3'
  movwf XX
  bsf FF, XX
I think I found the answer ... a little cumbersome but it does the job:
Code:
     ;FSR0 pints to the byte whose indicated bit will be set
     lslf PUSH01                  ;PUSH01 contains the bit # to be set, multiply it by 2
     movf PUSH01, w               ;load it into w
     brw                          ;branch the number of instructions
                                  ;as defined by the value of w
     bsf INDF0, d'0'              ;w = 0
     goto Exit_Setb_GPT02
     bsf INDF0, d'1'              ;w = 2
     bsf INDF0, d'2'              ;w = 4
     bsf INDF0, d'3'              ;w = 6
     bsf INDF0, d'4'              ;w = 8
     bsf INDF0, d'5'              ;w = 10
     bsf INDF0, d'6'              ;w = 12
     bsf INDF0, d'7'              ;w = 14
    ;goto Exit_Setb_GPT02         ;not necessary
Exit_Setb_GPT02:
God, I miss the 8051 architecture :confused:
