multiplying two numbers without multiplication operator
Kittu20
Joined Oct 12, 2022
511
I can multiply two numbers without using multiplication operator in c. I know that in recursion we call function inside function. I don't understand the recursion method for multiplying two numbers.
C:
#include<stdio.h>
int main()
    int x = 2;
    int y = 4;
    int mul = 0;
    // x = 0 + 2 = 2
    // x = 2 + 2 = 4
    // x = 4 + 2 = 6
    // x = 6 + 2 = 8
    for (int i = 0; i < y; i++)
        mul = (mul + x);
    printf("%d", mul);
    return 0;
https://www.geeksforgeeks.org/multi...iply-division-bitwise-operators-and-no-loops/
can someone explain math for multiplying two numbers using recursion ?
Papabravo
Joined Feb 24, 2006
22,113
Multiplication is just a shorthand for repeated addition of a number to itself a prescribed number of times. Similarly, division can be decomposed into repeated subtractions.
As a side note, the code fragment is NOT an example of a recursive procedure. It is just a simple looping construct. Recursion would invove repeated calls by a function to itself. Computing factorials in this manner is a classic example.
Here is the pseudo code for it:
Recursive Factorial Procdure:
fac ≔ proc(n) local s;
if n=0 then s≔ 1 else s≔ n*fac(n-1) end if;
return s;
end proc:
Notice how the function calls itself in the else part of the conditional 'if' statement. Each call results in a completely new stack frame for the function and when the top level return is executed the value return will be the required answer.
WBahn
Joined Mar 31, 2012
33,274
C:
#include<stdio.h>
int main()
    int x = 2;
    int y = 4;
    int mul = 0;
    // x = 0 + 2 = 2
    // x = 2 + 2 = 4
    // x = 4 + 2 = 6
    // x = 6 + 2 = 8
        mul = (mul + x);
    printf("%d", mul);
    return 0;
Your code does not scale well to large numbers. The number of times that your loop executes is equal to y. If you use your loop to multiply two two-digit numbers together, it will take a certain amount of time. If you then use it to multiply two three-digit numbers together, it will take, on average, ten times as long. By the time you get to multiplying two ten-digit numbers together, it is taking a billion times as long. Now consider how long it takes a human to multiply two ten-digit numbers together compared to two two-digit numbers -- perhaps fifty times as long. Ask a human to multiply two 20-digit numbers together, and they'll slog it out in about half an hour, while your program will likely take several thousand years.
As for the recursive approach, which is a REALLY poor use of recursion, the underlying math is simple.
z = x*y = x(1 + y - 1) = x*1 + x*(y-1) = x + x*(y-1)
When do you stop?
If y = 0, the result is simply 0.
This approach requires that y be a non-negative integer. We can relax the non-negative requirement by noting that x*y = -x(-y) and use that as our first check to get the ball rolling with a non-negative y.
As for dealing with non-integer values -- that's a completely different problem. The notion that multiplication is repeated addition runs into difficult when asked to multiply x by itself 3.872 times.
ApacheKid
Joined Jan 12, 2015
1,762
C:
#include<stdio.h>
int main()
    int x = 2;
    int y = 4;
    int mul = 0;
    // x = 0 + 2 = 2
    // x = 2 + 2 = 4
    // x = 4 + 2 = 6
    // x = 6 + 2 = 8
        mul = (mul + x);
    printf("%d", mul);
    return 0;
How big can the numbers get? A 2D array will work, just populate it with the products of integer pairs and you're done. You can save space too by recognizing that 2*3 is the same as 3*2 and so on. This approach has constant cost too, 3*4 is "computed" in the time same as 234*75.
WBahn
Joined Mar 31, 2012
33,274
This approach becomes untenable long before the loop approach does. Just to deal with 16-bit x 16-bit numbers would result in an 8 GB table, even after exploiting symmetry.
ApacheKid
Joined Jan 12, 2015
1,762
Indeed, I asked about the desired range too. I thought it helpful to show the OP there are often unconventional ways to look at these kinds of problem.
